Anyone have desk top dyno or similar
Old 06-26-2007, 12:15 AM
95FbFormula's Avatar
Default Anyone have desk top dyno or similar
I am trying to figure out some combination's that could be possible.
Old 06-26-2007, 11:27 AM
Rowdy94's Avatar
Originally Posted by 95FbFormula
I am trying to some combination's could be possible of
Do what?
Old 06-26-2007, 11:32 AM
Formula350's Avatar
I have Desktop Dyno
Apparently Ohio isn't prime learning location >_>
Old 06-26-2007, 11:36 AM
titter's Avatar
check out the engine analyzer pro from www.performancetrends.com ... free trial ... should get you going.
Old 06-26-2007, 01:56 PM
94 F-body's Avatar
the desk top dyno I have will not lead you in the right direction, try something else
Old 06-26-2007, 02:05 PM
Originally Posted by Formula350
I have Desktop Dyno
LOL I guess thats what I get for trying to watch TV and type lol oh well.
Thx I'll check it out.
Old 06-26-2007, 02:11 PM
daniel6718's Avatar
just tell us the modifications and well respnd with our in-my-mind dynos....theyre porobably more accurate also
Old 06-26-2007, 02:29 PM
pretty much whats in my sig. plus whatever bolt on i didn't list EWP 36# injectors. and whatnot lol. with it being dyno tuned. i just wanted to see if i could bring up a graph to see how my cam will react and were the power band starts. the SCR will be about 11.8 and DCR around 8.5-8.8
Old 06-26-2007, 02:36 PM
daniel6718's Avatar
well auto whenever they hit it its going to jump to 4500 and it will prolly be near 450 or more ft lbs and drop to around 400 at 7000
hp will be id guess 390 at 4500 and go up to about 425-425 at 6500 and drop to about 410 at 7100 or so
should be pretty close...flow numbers on the heads will help a lot
Old 06-26-2007, 03:27 PM
heads flow about 275-285 depending on casting and around 200-210 exhaust
That just the average though
Old 06-26-2007, 05:09 PM
speed_demon24's Avatar
It should run strong as hell at the track if you have all the supporting mods. 10's shouldn't be that hard to hit. Your 3600 stall might be a litttle on the small side though.
Old 06-27-2007, 01:31 AM
well i got some numbers with DTD but since i don't have all my cam specs yet since i waiting for it to be ground I used the 847 with 1.5rrs i would have done it with 1.6rrs but didn't feel like doing the math.
power at FW cam to be 574 @7000 and 493@5000
considering at 25% drive train loss it would be
431 RWHP and 370 RWTQ.
tq looks a little low but it's just to give an example and seems like the hp would be pretty close
Old 06-27-2007, 01:35 AM
Gun5's Avatar
whats the flow with ur port pro's heads i know my cam is samller but.. i should be running pretty quick when my cars done (check my sig)
Old 06-27-2007, 01:59 AM
Mine are still waiting to go out i sent them and email to get some flow numbers. they average around 275-285 for there stg 2 depending on casting i also used the thread asking about everyones flow numbers to estimate.
Like i said its just estimated its not perfect or exact the cam is have is very different from the 847 so i really don't know what it will make but should be close.
if you want give me some info and i can put it in for ya. will need the cam card though deck height. piston to deck height gasket thickness chamber volume and head type average flow numbers vith valve size
Old 06-27-2007, 02:04 AM
Gun5's Avatar
let me look its a Stage 2 Loyd EL, stock valve size
Lift Intake Exhaust
0.050 35.8 28.4
0.100 65.9 53.3
0.150 103.9 76.3
0.200 132.9 105.4
0.250 160.2 128.2
0.300 189.3 145.4
0.350 213.1 155.9
0.400 234.9 167.3
0.450 248.6 175.7
0.500 258.4 182.2
0.550 267.2 186.9
0.600 271.7 190.5
0.650 272.5 192.9
0.700 268.3 194.9
Max. 272.3 194.9
Avg. 194.5 141.7
355 (.30 over doh) its the felpro head gaskets
Old 06-27-2007, 02:21 AM
508@6500 479@5000 flywheel hp thats with the cam I had in still using 1.5rr specs.
subtract about 25% for rwhp. it will show a little low though. I would say you will probably be around 400-410RWHP
you cam specs would be needed for a better estimate also i cant add bigger injectors or the EWP. so those are probably really off
Old 06-27-2007, 02:25 AM
Gun5's Avatar
1.6 RR
http://compcams.com/Technical/Search...umber=07-305-8
my card in rl (When I had it) said 222/232 @ .50
Old 06-27-2007, 02:29 AM
what was the lift
Old 06-27-2007, 02:34 AM
Gun5's Avatar
what was the lift
they say .510/.510 eh with stock rocker so with 1.6 its what like 5.20 or 5.25??
isn't it 10 more?
