Engine removal walkthrough
Well I am attempting to pull the motor from the bottom and found the walkthrough in the newbie area.. I also did a search but never found another good one.
My main thing is where do I need to unhook the brakes and how do i need to do it.. I dont like messing with brakes.. prolly cause I dont really know how to do everything properly..
Any help is appreciated
I just pulled my motor out of my 95 this past sunday. there are 3 lines that run off the abs module. I undid the 2 lines for the front wheels. Leave the middle line hooked up, that line goes the rear breaks. You may have to remove you brake master cylinder to get to the one bolt for the shock tower. Once you go back together just bleed the brakes and you'll be good.
