383 Can Anybdy Solve This Fu@kn Prob
i have 383 i have a mis bout 4000rpm now i replaced opti wires plugs coolant temp censor had tune on computer dne cant figure it out plus it will run awsum for 15mins after that blows thick black smoke and wont idle wat the fu@k can this be sumbdy must have had this problem befor any advise would be great thanksssss!!!!!!!!!!!!!!!!!
Yeah sounds like it has issues once it hits closed loop. Look for a problem in the O2's or things that can cause false readings in the O2s. What exhaust are you running? Are you running headers? Do you have heated O2's? Do you have an exhaust leak before the O2's? What do the O2 readings look like when datalogging?
I third the O2. After the 15mins it goes into open loop and reads the sensors, when it hits the O2s. WHAM, the nastiness occurs.
I got my fingers crossed for you!
