fuel ????S
fuel ????S
fuel pump is getting weak...at WOT it pulls only 16lbs of psi ....so what type of fuel pump should i get...bout to put the nitrous on it and what type of pump should i get???
255lph (or gph, whatever they flow rate them at). Liter Per Hour and Gallon Per Hour *shrug*. Any of the top names you should be fine with. Walbro is the most well known.
