lots of new goodies
lots of new goodies
Sorry about the cell phone picture quality.
I've actually had the engine for about 3 months now.
Some of you may even recognize who's engine that is that is sitting there, if you notice a few of the details........
Picked up this Cromoly 6 pt. bar for only $250. Some LS1 car had a unlucky day and was parted out, I got lucky though I guess.
Ah now this showed up last week.
As you can see from the pictures, well I def. can't do the engine swap in the garage. I'm also hurting in the wallet now, so it will be a long time til all of this is in the car. I've got a lot of things to acquire before its all ready in any case, but big plans for down the road.
Looks good Corey. I'm looking forward to seeing when the transplant will start. Good luck!
FYI: The reverse flow cooling was a new thing they did when they started the Gen II LT1. Basically the coolant flows through the heads first, and then the block. GM Engineers did this so that they could run the LT1 at a higher compression from the factory and make more power than a typical Gen I SBC.
Originally Posted by TXFORMULA
i see. what is the advantage of it? what is wrong or why cant you use the reverse flow cooling?
Originally Posted by Revelation Z28
i dont know the advantage of it, but the people in the southern hemisphere use toilet paper to un reverse flow their toilets.
/end hijack
/end hijack
you killed the jokes.
he meant advantages of the paper towels
yeah, i know the lt1 has reverse cooling, but we were talking about what the advantage of getting rid of the reverse cool would be...
Originally Posted by camar0corey
Keeps the el cucaracha's out. I'd seriously be pissed if I went to pull something off and a black widow came crawling out or something, FL and those bugs man. And forgive my spelling, I'm not Spanish.
