What will it run?
What will it run?
I'm about to get my car back together and I'm curious what it will run it's a 95 Z28 350 with a turned crank, clevite bearings, scat rods, keith black flat top pistons, speed pro plasma moly rings, heads are milled 30 (apx. 11.5:1) and ported (flow around 260), cc306 cam, 1.6RR, 30lb SVO injectors, 58mm TB, 160 thermostat, MSD cap and rotor, MSD blaster coil, MSD 8.5mm wires, underdrive pulleys, deleted emmisions, pace setter LT's, 3in. true duals with X-pipe, 3,000 TCI converter, 3.42 gears, and a tune by madtuner.
Looks like you have all the supporting mods for a strong running H/C LT1. You should see high 11's in good weather if you can get it to hook. Those 3.42's might kill your et's a little bit but should still get you down the track, Id switch to 3.73's and a higher stall. good luck!
We don't have any 1/4 mi. tracks close to where I live all we have is 1/8 mi. so Im hoping for some 7.7's or 7.8's. Im wanting to slap a 125 or 150 shot on it. Hopefully that would put me in the high 6's or low 7's.
