need help with clutch?
i replaced the slave and the master cylinder for my clutch and my car still wont go into gear when its running. if i shut it off it goes in all the gears fine. it seems like its not dis engaging all the way. anyone ever have this problem?
PLEASE HELP!!!!
PLEASE HELP!!!!
yeah your pressure plate is toaste... get a new clutch... did you bleed the slave first? if not you might have air in it... to bleed it you need to hold it straight down and push the plunger in and out a few times and maybe you'll get lucky
its got a mcCeod street twin clutch. thats what i did to bleed that p.o.s. slave. why is there no bleed screw???? and the pedal feels really good. i never noticed a change in pedal pressure...
you need to buy the slave and master from gm comes together already bled just bolt up and go. Mine was doing the same thing when I replaced the slave and master individualy then I replaced it with the complete unit from gm and it is working fine now.
so i pulled the trany to check out the clutch and i found the springs on the clutch disc had broken. any idea if that would cause it to not shift? anyone ever had that happen?
