head replacement
Old 08-05-2007, 03:23 AM
transambandit's Avatar
Default head replacement
how hard is this to do, i am fairly mechanical, did my pacesetters and EWP etc on my lt1 but i want to know how hard it would be to replace my heads with a ported set?
Old 08-05-2007, 10:38 AM
9730thanvz28's Avatar
its not to bad. jus a pita when ya get to the back bolts to pull the head off. not to much room exspecially on the passanger side. drive side isnt bad at all.
Old 08-05-2007, 10:53 AM
urbanhunter44's Avatar
I found it a big pain in the *** but it's doable.
Old 08-05-2007, 11:00 AM
infinitebird's Avatar
yeah the main issue is that the motor is so far back that it's hard to work on.
Taking off some of the accessories helps.
Old 08-05-2007, 12:12 PM
95zpro's Avatar
You shouldn't have a problem doing this.
Old 08-05-2007, 12:31 PM
is there anything that i need to worry about screwing up? Tips for taking it apart and putting it back together?
Old 08-05-2007, 02:23 PM
FlamingChicken's Avatar
stay clean and organized. no real "experience" needed if you ask me. all you are doing is replacing parts. one thing i had a royal pain with was the coolant crossover in the rear. you can pull the heads with it connected but it might bend. I bent mine and ended up replacing it with a heater hose instead of buying a new hard line. Have fun and make sure to put a cam in there when all that **** is out.
