low mount alternator with power steering, help pics?
Putting an lt1 in 69 camaro. Will be running alternator and power steering only, would like to mount down low, just to give a cleaner look. I've seen several low mount alt brackets, to run alt only. Is there anything ready to go to run the p/s too. There was a thread on here where someone used a regal pump mounted on the left side, but I havn't had any luck contacting him to see what kind of belt setup he was using. That is the only one I have found that was running p/s also. Any help appreciated.
The car in this thread has the setup you want. I saw the car when I was over at Thunder Racing.
https://ls1tech.com/forums/vehicles-sale-non-lsx-powered/689591-sale-thunder-racing-built-96-ws6-formula-383-stroker.html
COntact him.
David
COntact him.
David
