Problem with AFR 210 Head HELP
Old 10-02-2007, 06:01 PM
Transamdrgracer04's Avatar
Default Problem with AFR 210 Head HELP
I cant get my head stud to fit in one of the holes on both heads has anyone else had this problem I am using ARP 234-4301 head stud which is what afr says i need to use. It looks like there is some metal piece in the hole keeping it from going through any suggestions or ideas
Old 10-02-2007, 06:05 PM
vanilla89's Avatar
take a pic
Old 10-02-2007, 06:30 PM
I will get a pic up as soon as my camera gets some battery back in it.
Old 10-03-2007, 03:31 PM
Turbo_6's Avatar
Could it be a spring shim that is slightly oversize? Are you running large solid roller springs/shims?
Old 10-04-2007, 01:33 AM
396Z28's Avatar
My spring shims were to big and i too had problems getting my bolts through. So i just mad adjustment to the washer i was using. But i didnt have problems with that hole i had problems with the middle bolt hole.
Old 10-04-2007, 01:40 AM
TwoFast4Lv's Avatar
I think you mean the center hole in the heads. We always have to grind the washers then move the springs with a pry bar or screw driver to get the bolts in
Quick Reply: Problem with AFR 210 Head HELP
