how to instal water pump drive shaft
just wondering if any of you guys have got any tricks to installing the water pump drive shaft seal because the tool is almost 100 bucks
I used a number of sockets to stretch out the seal, started with a small socket then worked my way bigger until you are able to slip in on the driveshaft coupler which should line up flush with the spline then you can just slide it over
