Another cam Q??
Old 10-15-2007, 02:05 PM
Big_Z_racing's Avatar
Default Another cam Q??
Im putting a hot cam kit on my 94 Z. I know there is better but im not getting into that......can my car run ok without a tune? i know a good tune will get the most out of the car since i have every bolt-on and free mod imaginable without getting into headwork, but i'm wondering if it's ok to even run the car without the tune?
one other thing, there is a bit of water and coolant when u pull the heads, but when i pulled the passenger side head off i had 2 cylinders full of water! car wasnt running right when i took it apart. head gaskets looked ok but r suspect. any ideas before i put this car back together??
Old 10-15-2007, 02:38 PM
SincalT/A's Avatar
The car will run fine without tunning.What do the plugs look like?The combustion chambers that had water in them should be diffrent than the rest.Most likley cleaner.
Old 10-15-2007, 02:49 PM
the car ran really rich and filed alot of plugs, but i couldnt say what those 2 looked like in particular. infamous opti **** a few times too.
Old 10-15-2007, 05:51 PM
96capricemgr's Avatar
If you are not going to reprogram don't bother modifying the car, it is as simple as that.
Probably get more from a tune on stock cam than you will from a cam on a stock tune.
Quick Reply: Another cam Q??
