95 camaro Z-28
95 camaro Z-28
I have a 1995 camaro with a cat back, MAF, Cold air, Hyper tech programer, shift kit, 3.73, Some suspension, and a 75 shot of nitrous. I went to the track tonight and i ran it all on motor and and the best i could get was a 9.08 with a .14 reaction. I was happy with that and then i was going to do a run Iwith the nitrous. I made a pass with the nitrous, and made a 8.98 with a reaction time of .22. I dont know what is wrong i only dropped .10 of a second. I cant figure it out but i do know that i should drop more than that. Does anybody have any ideas of what is wrong? When i hit it you can feel it a little, When i pruge it i have never been able to get it to white smoke???? When i do hit it, on my air fuel gage it is reading rich and i have 35Lbs of pressure in my fuel line. ANY IDEAS????
I know this sounds stupid but are you sure you got it set to 75, Ive made the mistake of thinking 150 and actually being 125. The white smoke, could be the nitrous, remember the purge is to get the air out of the line, once its gone theres nothing but gas. Not trying to insult your intelligence either. But times on the track are half car and half driver. Have you hit the track alot or is this one of the first few runs. It could have just been a bad run, weve all have had them.
Probably the hyper tech programmer! LOL! I would try it again a few more times to get some more results. Your fuel pressures could be a little low, its suppose to be between 40-42 I believe...
This was my first time, at the track and the car ran the best it has ever hooked up like no other! I actually cracked my fender and my dash when i launched. (OUCH) But they are they right jets. I have never been able to get white smoke to come out of the purge NEVER. My 60 Foot Range from 2.07 to 2.15 with 78.93 MPH. I was talking to a few people and they said that i should be dropping at least .50 with a 75 shot, and i just cant figure it out. Ohh yeah my fuel pressure is 35 psi and that is what a stock one is soposed to be.
It very well could be your fuel pressure dropping when hit the fun stuff. I would get a fuel pressure gauge, its just good to have so you can monitor it at all times. Other than that I have never had that problem...but my car was not stock when I starting juicing. Check the fuel pressure...see where that goes.
