thinking about selling my car, details inside
Im kicking around the idea of selling the car for another one i found. Im not killing myself trying to sell it so im not gonna take low ballers. Heres a list of what i could remember right now so im sure theres a few things i missed. Not to mention all the hours of doing the mods myself. Id like to get $9,000 for it. Everything on there has under 1,000 miles on it including the trans rebuild and i never got a chance to spray the car eaither (no joke). The car was rearended last year but no major damage, just typical body work. CLEAR TITLE!!
CAR
--1994 Camaro z28
--101,xxx miles
--no rust on body at all
--no rust underneth, garage kept
MOTOR
--custom CAI
--58mm throttlebody
--TrickFlow intake elbow
--ported intake
--stock heads
--comp. cams 918 beehive valvesprings
--+.050 locks
--Ti retainers
--new valve seals
--GM847 cam
--new gm timing set
--newer GM opti
--new felpro oil pan gasket
--MSD 6al box
--MSD digital window switch
--Taylor plug wires
--TR-55 plugs
--CSR electric water pump
--low mount alternator
--deleted all acceries on motor
--Wet Nitrous Works nitrous kit with NOS bottle
--Pacesetter coated longtube headers
--extension's with bullet mufflers then dumped
DRIVELINE
--TCI flex plate
--Vigilante converter 3200 stall
--FLT level 4 trans with vaccum mod.
--trans cooler
--aluminum driveshaft
--10-bolt with torsen posi. unit
--3.73 gears with TA girdle
SUSPENSION
--welded in subframe connectors
--bigger sway bar in rear with welded brackets on the rearend
--stock springs with 1 coil cut
--stock shocks
--Behind Bars race cars panhard bar
--UMI torque arm with driveshaft safety loop
--front QA1 "R" coil over shocks
INTERIOR / EXTERIOR
--VFN 3'' SS fiberglass hood, pin-on
--no windshield wipers or motor, everything gone
--car still has power locks and windows
--Weld Prostars with Goodyear front runners and M/T ET street tires
--stock front power seats
--no carpet (still have)
--no rear seats (still have)
--no interior trim pieces (still have)
--Grant steering wheel
--HVAC block off plate
--stock radio with 2 door speakers, no rears
--no visors (still have)
--fuel pressure, oil pressure, water temp, nitrous psi, trans temp. gauges
--Dash has been removed to strip out weight from behind it
--both air bags removed
--msd 6al box and window switch is mounted inside on the fire wall
--removed ABS
--TCI line lock
--battery mounted in rear
--no heat or acc.
--no AC or acc.
--no e-brake or handle
CAR
--1994 Camaro z28
--101,xxx miles
MOTOR
--custom CAI
--58mm throttlebody
--ported intake
--stock heads
--+.050 locks
--Ti retainers
--new valve seals
--GM847 cam
--new gm timing set
--newer GM opti
--MSD 6al box
--Taylor plug wires
--TR-55 plugs
DRIVELINE
--TCI flex plate
--trans cooler
SUSPENSION
--stock shocks
INTERIOR / EXTERIOR
--removed ABS
--TCI line lock
--no heat or acc.
--no AC or acc.
