Tripometer
Old 11-19-2007, 11:34 PM
zlightning's Avatar
Default Tripometer
My tripometer no longer works correctly. It has not been chaning over to 100 miles and one day last week it finally made it past the 100 mark. Well I thought something might have been knocked back into place. Then on my way to St. Louis(opposite side of Missouri) it stopped at 49.9 miles, I reset the tripometer and now it has trouble turning over to 10 miles. I was wondering if I could just buy a used cluster and replace my tripometer with that of the used cluster. I'm sure that is legal and does anyone else have this problem?
Old 11-20-2007, 01:11 AM
jester1614's Avatar
the cluster swap is pretty east and it is plug and play. I am not sure if there is any other way that swapping the entire cluster
Old 11-20-2007, 06:23 AM
Internet Mechanic
BlackScreaminMachine's Avatar
You can try to fix it, I am assuming you have a 93-96 LT1, the issue is its never right. My bud's 93 had the same issue, we took it apart and it worked for another 1000, i think when its fucked, its indeed fucked.
Old 11-20-2007, 08:26 AM
zlightning's Avatar
That's good to know, I just use it to calculate MPG so it's not really a big deal. I was going to write a simple computer program to tell me what gas stations get the most MPG anyway.
Old 11-20-2007, 09:13 PM
YngBird's Avatar
yep,your fucked.i have a 93 and mine stops at 9.9,every time.after some research,iv'e come to the conclusion that it's not worth the fix!
Old 11-21-2007, 07:22 AM
Internet Mechanic
Woot 2 quotes in one post for me!!
+1 Post count!
Quick Reply: Tripometer
