Need some numbers ran. . .
Soo, with a 383 stroker LE2 head setup with like a cc306 cam 58 mm throttle body SLP LT headers running through duels. . .what kind of power am i looking to throw down I want an N/A beast *that's plenty streetable* and i plan to have a daily so i can build it. . .Also lemme know if i should get a little more aggressive or not. . . .I wana be able to drive the car around town with no problems and i figured this was pretty aggressive . . .should i go LE3 give opinions throw out your opinion on power. . .Also i'm kind of looking for an 11ish second area. . .plan to add a 12 bolt for power and some drags for that kind of run. . .
with a 383 it might be a good idea stepping up to the LE3 porting being that the cc306 is a pretty good sized cam along with the extra cubes your going to want to let that thing breath
from what i've seen here you shouldn't have a problem making 400-430 rwhp
