Ram clutch???? T56 guys come inside....
should i go with Ram Powergrip HD or Spec 3......? running 450rwhp want to have as a good street strip car but mostly street. should i upgrade the flywheel to billet steel? r the billet steel flywheels all the same or should i stick with a certain company? Thanks.
Where are you getting it from? Check this link.
This is straight off their website:
Powergrip HD Clutch sets
Powergrip HD sets are the ultimate for extreme street/strip performance. Using our proprietary 900 series friction material in conjunction with increased clamp load pressure plates, you get maximum holding power for track or street, with only minimal reduction in driveability. This is the set for big power street cars! Some chatter will occur on takeoff. Use only with RAM billet steel or factory nodular iron (explosion resistant) flywheels.
True Balance Billet Flywheels
All billet flywheels are NOT created equal! Every RAM True Balance flywheel is turned, drilled, and tapped on our own CNC equipment from SFI certified materials. Aluminum flywheels get a replaceable carbon steel friction insert. Flywheels are then precision ground parallel to the crank flange and to the proper RMS finish for optimum mating of the friction disc. Shrink fit ring gears are replaceable; one piece flywheels require replacing the entire flywheel! Finally the flywheel is digitally balanced to the proper factory specification. When you purchase a RAM True Billet flywheel, you can buy it, bolt it in, and go!
haha.. didn't even read what I posted that well... missed the aluminum part... well, SPEC does have a billet steel one and ThunderRacing sells'em too.. thats where I got mine.
http://www.turbotechracing.com/produ...idproduct=4608
this is the flywheel im using with my stock motor w/ HAY85-125 - Hays Street Clutch Kit and its so awsome the motor rev's somuch faster with the alumflywheel
yeah for 450 rwhp i say go with stage 3+. mcleod single disk would be a great choice too. As far as flywheels for daily driving and drag racing steel flywheel is what you want. Its heavier but also carries more momentum which makes it easier to launch. Aluminum is good for autocrossing and road racing so you can rev faster and make it easier to rev match etc
