OMG!!! Tranny wont shift! its on teh trailer! HELP!!
So i was driving down a local highway and everything was running normal when BAM! I try to upshift into 5th and she wont go, then i try to go back to fourth and she wont go, i try any other gear....she wont engage! So i pull over and turn the car off thinking maybe the transmission is just off. I can engage all gears while the car is off, the clutch feels normal. However, whenever i turn the car on right after shutting off....i hear this hissing/whine noise that i've never heard before. Also, we let it sit for about 3 hrs at a gas station and came back, same story. The hissing was gone but in order to get the car into gear it had to be pushed VERY VERY HARD ( like....i used both hands and im not a weak guy ). i realize this isnt right, so when the car tries to move while in gear, the whole car shakes. I dont know what is going on but i suspect either the clutch, slave cylinder or throw out bearing is bad.
Any ideas guys?
Any ideas guys?
thats what i was thinking too. the reason i dont think its the TO bearing is because it does it with the clutch fully engaged right? if so, the TO bearing is not being used at this point
