lt1 help i think o2 sensor ??????????
its a 97 trans it has long tubes and some other little things. but when i drive it studders until i slam it to the ground then it takes off pretty good. and if i go up to the next gear when its studdering it stops a little and it seams a little rich. i get the code p1661 but thats i wide verity of things (mil circut)
it has new plugs and wires all on tight and the maf sensor has been change to see if it was that oh and the map sensor been change. so what you guys think.????
