Crane Ignitions (Will it work with my OBDII Camaro LT1)
I hope you guys can help me out
Here is what I wanted to set up
Crane 6000-6466 - HI-6TRC w/Timing Retard
Crane 730-0892 - Crane LX91, LX92 Coil
Crane 6000-6708 - GM HEI w/Ext. Coil Adapter Harness
I just tried ordering these thru' Summit, but they told me it wasn't compatible with my LT1 - because it has an optical trigger.
Looking at the fine print I can only find that the coil is only for 1995 and older non-OBD II vehicles with distributor-type CD ignition system.
Contacted Crane they reckon it "should" all be OK.. Wish they said WILL be OK.
On GMHP the fit a similar ignition, but with a magnetic trigger..
Whats going on ?
Have any of you guys installed these to your engine ?
Any & all info would really be appreciated.
Rob
Whats going on ?
Rob
