Front Gaskets
Front Gaskets
So my car is starting to leak worse and worse. I just drove an hour and my car was parked for 2 hours and i noticed 4 spots where oil has been dripping on my driveway. I'm pretty sure it's coming from the front of my motor but I'll find out tonight. So my question is how hard is it to replace these gaskets? My intake gasket was replaced and doesnt leak and my valve cover gaskets are fine so the only other two are the rear main seal and the timing chain cover gasket correct?
I changed mine in about 3 hours taking my time. It is like changing a opti but you need to lower the oil pan(or drop it). If I were to do it again i would just have dropped the oil pan instead of lowering it. That way you dont have to worry about it leaking later. good luck
Internet Mechanic
You have the timing chain cover seal, the oil pan gasket and you have the seals for the WP and Crank the Oil pan is a one peice but when you drop it, you need to redo it, to do it right.
I dropped mine when we did the cam but it never was right. Being a tight spot never help either, It needs to be clean and dry and tight bolts to help ensure the seal.
Also the timing chain cover can be taken off before the pan but when it goes back on the pan needs to be dropped and great care is needed for the timing chain seals.
