Guide To swap motors
Does anyone know where to find the guide to pull the motor out of the top. I have seen multiple ones to remove it from the bottom and I do not have a way to do that.
Hey man. You dont need a manual. I pulled mine out the top. The easiest way i could find was taking the whole top end off the engine and EVERYTHING out of the front. Radiator, condensor......etc. Make sure you take the balancer off to. When you get the engine lifted up high enough take your motor mounts out of the car.....it'll give you a lot more room to twist the engine sideways and give you oil pan clearance. It really wasnt that hard though. I ran 4 head bots in the block, one in each corner with a chain crossed hooked on it. Hook it more towards the font so the back drops just a touch. You shouldnt have any problems doing this. I did my wifes 96ss this way and also my 98z just this past weekend. Hope this helps ya .....good luck
its easier to not use that leveling bar. Just use a chain that is connected to the four center most bolts. Its best to have a buddy with you. I have pulled out JUST the motor and the motor + tranny using this method. Yesterday i just dropped in my new longblock in, i even had the pully and headers + oil cooler on when i did this, was cake.
