car ignition problems?
I don't have a book for this car but these codes come up 36 high resolution pulse ckt 46 pass key, 42ignition ctrl grounded ckt,ignition ctrl open ckt can some body tell me what all this means how screwed am I? and the car is a 94z28 with an automatic
code 36 is an optispark code (distributor) the optical sensor isnt reading the pickup wheel's 360 outer slots. it may be possible there is blockage, or just a tired optical sensor.
code 46 is for your VATS anti theft system, you may need a new key, or lock cylinder cleaning/replacement or the VATS system has a problem.
code 42 you would need to look at all of the harness wires/grounds for the ignition system.
the car is really unresponsive I cant even rev car at all sputters and backfires would this the opti spark only or partially some of the other codes? do i need to replace whole dist or can I just replace this sensor?
i had the low resolution code being thrown due to alot of rust inside of the opti, and the optical sensor wasnt picking up the pickup wheels 8 larger slits so it didnt know when to fire the injectors or kick on the fuel pump. your high resolution is to fire the rotor so it knows where the crankshaft is, thats why you arent getting a good response, it isnt firing right.
