lt1 questions?
lt1 questions?
Ijust bought a 1994 lt1 with a bad engine , so we took it apart , it has aluminiun heads , does all lt1 came with aluminum heads?
The camshaft has a number #970709, does anybody know what time of cam this is , looks like a stocker but i'm not sure,also the clutch is a valeo clutch kit , are those any good?, should i put the same one cause i'm shooting for 360 rwhp with my new cam and port job
The lift on a stock aluminum cam is .450/460 with 1.5 so measure it if it is different you know it is not stock the same delve deeper.
360 RWHP will be a reach...you will need head exhaust, cam etc
Good luck
Jack
