Stumble at mid-throttle or higher, idle RPM erratic
Old 04-28-2008, 11:05 PM
Compstall's Avatar
Default Stumble at mid-throttle or higher, idle RPM erratic
I JUST got the car back together. All this was for an opti change originally. I just changed the cap/rotor. Now the car runs worse than before. I used a Jeg's cap/rotor. I don't want to immediately say that the cap/rotor is bad out of box...
I had the same symptoms of opti problems in the past - runs fine when cold then hesitates a bit under throttle when the engine is heat soaked.
I'm wondering if I may have crossed a couple plug wires to the cap. If I did do that, wouldn't I get a code? I let it idle for a while but no codes showed up. When I go to take it out of gear and coast to a stop the engine drops down to ~700 rpm then picks back up again.
When the engine is idling, the idle RPM is up and down. It will idle ok for a few seconds, then drop and rise.
Maybe it's hard to tell with a cam in the car, but I would think that if I got 2 wires crossed it would be fairly noticable?
I'll check the wires tomorrow after work, but if that ain't it, the only thing I messed with was the opti. I might have to just order a complete OEM unit and try again...
