Weird vibe after cam swap
I have a vibration at about 2000 to 2400 rpms and think my damper is put back on wrong after a cam install???? I bought a car on fleabay and never did anything with it till I cut it up for a rear quarter I needed for one of my other Camaros. Long story short the guy said he put a new clutch in the car then I put a hotcam kit in it and after a couple years put the motor into a real nice HT V6 body I found. Now the car runs like a raped ape but has a vibe around 2000-2400 RPMs. Could this be from turning the flywheel and not balancing or me putting the harmonic balancer back on the hub wrong.?
Thanks for reading this long story and any input, Tom
The damper only goes on the hub one way and the hub is not keyed to the crank. That is not the cause though as it is all neutral balance in the front of an LT1.
The rear of the motor is external balance but I would not think turning the flywheel would affect that long as the weight was left alone.
vibe
The flywheel is weighted as Dwayne says....but it must be lined up so the pin on the crank lines up with the allignment hole on the flywheel. If that pin was removed from the crank the flywheel will bolt to the crank in any position.
There is also a alignment 'paint dab" on a stock flywheel and a clutch pressure plate. Those most be aligned. aftermarket or replacement flywheels do not have that paint dab.
On the attached pic you can see the "7th" hole in the flywheel where the pin goes. I have a "neutral" aka "internal" balanced motor so the pin on the crank was removed for balance purposes. You can see the "balance" pins for the flywheel in various holes on the outer edge of the flywheel the machine used to neutral balance the flywheel (after grinding off the original cast weight on the flywheel). The PP was also neutral balanced with the flywheel as a unit.
Your vibe could be for other reasons but you need to confirm your flywheel & clutch positions are correct and also confirm if you have a internal balanced motor or stock external balance motor (rear).
