Battery Help needed!
I have a 1995 TA and one year old yellow top optima. I noticed lately my battery guage drops from 14 amp reading to around 10 when sitting in traffic. Is this normal? I thought the reading would hold around 14 amps all the time. As soon as I apply the gas it jumps back to 14 reading. I also have two subs/amps in the car and it does this with and without the radio on. Is there something drawing a charge and if so how do I check it? Maybe this is normal and I just noticed it was doing this a few days ago. Car starts ok as well.
Any ideas? Thanks
Any ideas? Thanks
I would suspect the alternator more than the battery. My car did something very similar, and I tore the alternator apart to find the internal brush holder (plastic!) had broken -- brushes weren't making good contact with the commutator armature. I'd also double-check the exciter wire on the rear of the alternator -- sometimes the female terminals of the electrical connector fail.
THEN maybe I'd look into battery/cables.
