Accessory bracket replacement
I have the alternator off with no problems there, but now I'm somewhat confused. I see one bolt for the power steering pump but the lines going into it are solid and I don't see how to get them off. I don't think it is possible to get the thing off and the new bracket in without removing this stuff. Assuming I figure out how to get the lines off, don't I need to drain the system first? Where and how? Then there is the AC compressor that I haven't looked at yet. Do I need to remove the pulleys? Also, would it be easier to get everything from the bottom?
