Need Help With Pushrods!!!
I have the AFR 210cc cylinder heads.... specs here
--->http://www.flatlanderracing.com/afr-sbc210lt4.html along with the GM LS7 lifters......... and 1.6 ratio full roller rocker arms.... Can someone please help me figure out what length pushrod I need so I can finish my build! Thank you for any suggestions - Jason
bring #1 cyl to TDC, remove RR and mark top of valve stem with a marker, put RR back on and lash that valve, turn motor over 2 revolutions, remove RR.
If witness mark is "dead" center on valve stem tip you are cool. If mark is closer to exhaust manifold a shorter PR is needed, mark closer to intake a longer PR is needed.
A $12 PR check tool is handy to check for "actual" length.
every motor with aftermarket cam, heads, head gasket thickness, RR, valve springs willl measure differently so you can't say "XX" fits your set up without measureing.
If the stock PR is not exactly right....it should be "close"....your call on weather "close" is good enough.
I got the checker while doing my build, and some 8inch digital calipers from harbor freight to measure. I then hit up manton for the pushrods. (they look like the holy grail of pushrods.)
Village Troll
drumbo87-
Do what ****** said and post the pics up here. You can use a Sharpie to mark the valve tip. Hopefully you know how to adjust rockers?
