Question about ignition switch
what have you guys found out to be the easiest way to replace the ignition switch.. i have a 95 TA w/LT1 , A4.... I've dropped steering column and wonderin what the easiest way might be to go about the rest of the replacement.. thanks for any info....
you just have to get in there and do it you will be in some weird angles. Be careful with the back screw it tiny and easy to loose (Dont Ask) getting it back in is even more fun Once you have it back in dont put everything back yet 1st make sure it starts then shift the gears then make sure the car shuts off easy and the key goes to the off position without getting hung up also some people forget to take the 3 screws that are on the firewall were it goes thru. if you have a specific ? let me know ive done it a few times
