What brand 42lb injectors?
Going to go ahead and upgrade from 30lb svo's to 42's since the car made 437rwhp with a few hiccups. All things are fixed and will be doing another tune to for good measure. I've looked at the flow matched racetronix, speed inc, bosch green tops. Are there any benefits to one over the other?
I bought a set of ford racing green top injecors for my 396. the first time i used them they flooded my car with gas. i would not use them ever again. i ordered a set of delphi lucas and they worked perfect!
Figured I'd include a few details in the motor it's a 12.38 to 1 comp. 383 with LE2 heads and a LE3.2 cam, LE ported intake, kooks stepped headers, ALL bolt-ons. The 437rw was with a bad miss, bad gas, and I found out that I was sucking oil in the back cylinders. Oh the compression was higher at the time I had the .029 gaskets on it and went to a .040 gasket. I'm tryin to milk everything I can out of her. Thanks for all the help so far.
