The Problem
The Problem
If I were to describe the prob, this is it:
At idle I get random surges, sometimes I dont quite get them, sometimes I do quite a bit. When im driving the car will start to jerk a bit as it hesitates a moment then gives a small burst of rpm. At wot, there is a sound that doesnt seem right, like a shifting between shifts or something.
Setup:
K&N cai
Pacesetter LTs
94 tranny in a 95Z with pcm tune
Yank 3200 (installed with 94 tranny when put in 95)
Stuff ive done:
Replaced a couple hoses to the throttle body.
Looked over vaccum hoses
Checked the egr and cleaned it
Sprayed the MAF with MAF cleaner
Sprayed the throttle body with throttle body cleaner
Made sure the plug wires were pushed into the spark plugs
Checked for exhaust leaks and tightened bolts
New o2 sensors
Ordered today:
TCC solenoid
MSD ignition coil
Any suggestions would be helpful, thank you.
Setup:
K&N cai
Pacesetter LTs
Stuff ive done:
New o2 sensors
Ordered today:
TCC solenoid
MSD ignition coil
There not too old but just picked some up to install tmw. Also picked up an ignition coil and tps sensor as well as the tcc solenoid. Figure ill just go through the list. Saving the solenoid for last.
As far as scanner, I have a friend with one, but dont have one myself. Might be getting one in the near future to save time and have a better idea of what im looking for.
