injectors?
injectors?
what are the stock injectors on a 94 lt1 camaro? and do i need to upgrade them and the fuel pressure regulator? my car just has bolt ons with lt headers and a lt4 hotcam with 1.6rr. thanks for the info
The stock injectors in a '94-'97 LT1 are 24lbs. and they should be sufficient for your setup. I wouldn't bother upgrading them or the fuel pressure regulator. If you were to add heads or something like that then I would upgrade to some 30lb. SVO's but your 24's should be fine.
thanks guys. i have got the motor all back together and ready to drop it back in the car. cant wait to here the cam.
how will it run with out a tune?
