need help with freescan/vemaster
Old 09-17-2008, 08:49 PM
Grr
Grr's Avatar
Default need help with freescan/vemaster
I am doing a 2-bar setup using the stock PCM and i am having problems using vemaster. It will only load values into cell 16, i save the .csv file and load into vemaster. If i scroll all the way to the bottom the last line is the only one with any change/info in it. Im not familiar with this program (just HPTuners and EFILive) any help would be appreciated.
Also does anybody else run a 2-bar setup in here? If you could PM me your file so i have something to compare to that would be nice. Other than that the car runs fine so far, i have gotten a little ve tuning done at idle and stuff but kinda hard to do without that info.
Gary
