gm 847 w hotcam roller rockers
Old 09-19-2008, 01:35 PM
th3brandon's Avatar
Default gm 847 w hotcam roller rockers
just as the title states would this work with crane springs 10308-1...i have the hotcam kit now looking to upgrade to a 383 w the gm 847 cam, but use the roller rockers off this kit to save some cash for new lifters and pushrods ect..
Old 09-19-2008, 02:40 PM
PNYKLR-TA's Avatar
10308-1 springs are whats in my car with a cam with a .565 and .576 lift with 1.6RR's
and they seem to be working fine for me, im not exactly sure what the max rating is on the 10308-1 springs are thou i always wondered.
Old 09-19-2008, 10:43 PM
LSWHO's Avatar
10308 is what I'm doing when I go 847.
Old 09-20-2008, 01:15 AM
KMStevens's Avatar
sorry to hijack, anybody running the k800 springs with this cam? Im gonna use them with comp pro mag 1.6 nsa rr's for my cam setup.
on a side note, coming from a former LS1 owner to an LT1, LT1 parts are sooo much cheaper than LS1 stuff, may not make as much power, but I'll take the savings and use it for more nitrous refills lol
Old 09-20-2008, 06:54 PM
StealthFormula's Avatar
.600"
Theres more than just max lift ratings lets not forget
With the rpm's you will be spinning I would go with NSA Rockers without doubt. Not saying SA wouldn't work just not the best idea to run SA Rockers on motors that spin mid 6000's on up.
Old 09-20-2008, 07:14 PM
SoxXpupPeT's Avatar
Originally Posted by StealthFormula
.600"
a novice question. so with those springs on stock LT1 heads youll get .600" max lift off the cam ?
Old 09-20-2008, 07:22 PM
The lift rating refers to how much lift the spring can physically handle before going into coil bind. The lift of your cam will not change.
Old 09-21-2008, 07:51 PM
th3brandon's Avatar
ok or these rr will work fine for now...maybe ill get a set of guildplates to help as well
Old 09-21-2008, 08:15 PM
Guideplates are for NSA Rocker Arms, thats how they keep aligned. Need different studs to run guideplates as well as hardened chromemoly pushrods because they run against the guideplates and must be hardened for strength purposes.
Old 09-21-2008, 08:21 PM
th3brandon's Avatar
Guideplates are for NSA Rocker Arms, thats how they keep aligned. Need different Studs to run Guideplates as well.
yea my bad i meant u dont know wat i was thinkin thats wat happens when ur only 18 with a f body
Old 09-21-2008, 08:32 PM
fergymoto's Avatar
Do not run guideplates with the SA GMPP rockers. Just sell those rockers and get some Trickflow (reboxed Crane Gold), Crane, or Comp NSA rocker arms.
Old 09-21-2008, 08:34 PM
thats no excuse Im 20 lol its all good bro, gl with the build!
Old 09-21-2008, 09:15 PM
SoxXpupPeT's Avatar
.600"
oh i know that. i was just asking what the max lift would be tha the springs on the stock LT1 heads would be before binding
Quick Reply: gm 847 w hotcam roller rockers
