zr1 clutch ?
Old 11-13-2008, 03:14 PM
themack56's Avatar
Default zr1 clutch ?
ive searched, but i havent found an answer to my question, cant some sponsor on here, make a flywheel that is the same as the zr1 clutch, but witht the bolt paterns for an ls1 crank. So it can be possible to use the twin disk clutch?
Old 11-15-2008, 01:06 PM
themack56's Avatar
no one knows?
Old 11-15-2008, 03:28 PM
SNLPerformance's Avatar
Anything is possible with the right amount of money.
I will speak for us only, we are in the process of finalizing a 10.5" twin disc that will drive like stock, have the same or less pedal pressure than stock, and support 1,000hp/tq. It will be heavier than the twin we currently have and be a damn nice clutch for the street. The problem with the ZR1 clutch is cost. By the time someone bought the clutch, had a flywheel made, and got everything sorted out, you'll be out more than what my 10.5 twin will be.
Keep an eye on us, we'll get you a twin that will support what you have and give you the pedal pressure and smoothness that you want.
Steve Addison
SNL Performance/Monster Clutch Co.
817-750-2000
