swapping input shafts
Can anyone give me any insight as to the difficulty in swapping the front shaft from a 97 lt1 6speed with a ls1 input shaft. I am installing the 97 t56 behind my 2002 ls1 in a 1956 belair and dont want to screw anything up but i havent been able to find any manuals online that shows the precedure
There were a few write-ups on this forum, some with pics, of doing it by just removing the front plate. You'll have to check/set the 3 shim values, because you'll have a new shaft and plate and different clearances.
If your LT1 trans is stock and has a few miles on it, you may want to just tear it all down by the manual, and put new CF blockers, fork pads, 3/4 fork, billet keys, etc. and start off fresh.
I have an aftermarket hydraulic throw out from classic chevy that has its own adsjustment and just slides on the shaft with no attatchment to the tranny it is for installling a ls1 in a hot rod application
