LS7 clutch on CTC-v t56
Is the CTS-v T56 already working behind an LS6 block, Clutch&FW? The CTS trans inputshaft is slightly shorter than the LS1 and uses a different slave hyd hookup&bell configuration, but there shouldn't be any reason the LS7 clutch&FW won't work. If you're starting from scratch, you need to check the slave setup and the pilot to make sure everything is in synch.
