my ram vds clutch broke,which twin disk for 625rwhp?
Old 07-13-2009, 06:23 AM
blackls1ta00's Avatar
Default my ram vds clutch broke,which twin disk for 625rwhp?
since having my ram vds clutch break when i was doing a burnout at the track and with only 2500 miles on it what gives?,im needing a tough clutch thats gonna hold at least to 700rwhp.im thinking about the textrailia twin disk any opinions?
Old 07-13-2009, 09:48 AM
Kurtomac's Avatar
heres an opinion...stay away...stay far far away from the tex twin
Ive had good luck with my Spec Twin...I got the 1395lb tq capacity PT trim
Old 07-13-2009, 11:27 AM
SPEC-01's Avatar
I would second Kurt's suggestion...though I am a bit biased. If you are happy with your current power level and don't plat to go any higher you would be just fine with the SC09SST which is rated to 900ft.-lb. I drive one of these daily and it is very capable as both a daily driver and abuse taker. Give me a shout if you are interested and we can discuss options. By contact info is below. Thanks,
