replacing input shaft..any easy way to do it?
Old 09-04-2009, 08:24 PM
2000ws6transam's Avatar
Default replacing input shaft..any easy way to do it?
i haven't done too much research yet but it almost looks like i can pull the front cover off and do it all without much work? any info vids article links exc. would be great its my first time in this trans and i don't know much about it. thanks everyone for all the help!
Attached Thumbnails replacing input shaft..any easy way to do it?-broken-input-shaft-004.jpg   replacing input shaft..any easy way to do it?-broken-input-shaft-001.jpg
Old 09-05-2009, 03:00 AM
jmd
jmd's Avatar
You can but you'll still need to check bearing preload on the input/mainshaft tapered bearings.
