I didn't get any instruction with my TICK MC :(
Well, if everything's installed then all you have to worry about is adjusting the pedal travel. I have mine set out from the floorboard pretty far cause I like the clutch to engage a little higher in the travel. Don't set it out too far though, they say it can damage your clutch.
As far as the bleeder, if it has a solo bleeder on the end then all you have to do is crack it and pump the pedal till you get all the air out of the system. Just make sure to keep fluid in the reservoir.
Here ya go bro. I remember it being a pita, but I have some big paws.....and it goes in a little area.
if it doesnt pull up good shoot me an email at raron455@yahoo.com and I will send it directly to your email
If someone could email me the instructions I would appreciate it. Gen414 I bought my m/c from you, well my clutch too. It should be going in next month. I will finally have some feedback on the clutch for you.
Email is: LilJayV10@insightbb.com
Thanks.
Thanks.
