crossmember help
crossmember help
Hey, I'm doing a swap into a 1974 2nd gen F-body. I already have the transmission in the car and everything hooked up except for the crossmember. The solution I had for a crossmember is no longer a solution but a problem and I was wondering if anyone knew where to get a 2nd gen F-body LS1 styled T-56 crossmember. This is going behind a Gen1 sbc engine btw, not an LS series.
