Leak but no fluid on the floor ??
Stock t56 stock master and slave. Bleed the master two weeks ago clutch felt better but still soft. Went out last night to look things over and the resivor for the clutch was almost empty after just being topped off when I bleed the system. So I filled it back up took a cruise(100miles) checked it the next day and same thing low on fluid but no visible leaks. Not a single drop on the floor or even a drop waiting to fall. ???? Its got to be going somewhere
