Clutch Cruise Switch?
So I just had the Master Clutch Cylinder replaced on my 1999 Trans Am, they called and told me that the Clutch Cruise Switch was broken, and that I won't be able to use Cruise Control. I mainly drive that car around town so it's not dire, but I will want it repaired. where is it located and is it honestly just a switch?
It's a simple switch that the clutch arm engauges when the pedel is up. It is a white switch that fits in a bracket under the dash. It should be very easy to replace.
