I can't get my clutch to bleed!!!!
Old 12-21-2009, 06:59 PM
TblackTA's Avatar
Default I can't get my clutch to bleed!!!!
I put an LS7 clutch in my 1999 TA and I cant get it to bleed, but it feels soooo close. I've tried the mighty vac and every way I or anyone else at my house knows
Old 12-21-2009, 07:16 PM
Wesmanw02's Avatar
What method are you using to bleed it??
The best way is to manually bleed it. Have someone hold the clutch to the floor, open the bleeder, let it bleed out air/fluid, close the bleeder, pull the clutch back up, and repeat.
Old 12-22-2009, 09:19 PM
TblackTA's Avatar
thanks but i figured out my slave was bad, i replaced it and im gettin closer but it is still being a pain like they usually all are.
