Tick Performance Remote Clutch bleeder Line Worth it?
Old 01-16-2010, 07:53 PM
CranMaro99's Avatar
Default Tick Performance Remote Clutch bleeder Line Worth it?
So I am going to be buying the LS7 clutch package pretty soon here as my stock clutch is on its last leg. I am also going to buck up and get the Tick Perf. adjustable master cylinder installed as well.
I was wondering, since I'm spending that much dough anyways, should I get the Tick Performance Remote Clutch Bleeder Line (for 50 bucks) since I'll be installing the master and clutch anyways?
I'm pretty sure I'm going to, as it seems like the line is long enough to feed it towards the clutch fluid reservoir, eliminating the need to be under the car during a clutch bleed, which makes that extra 50 bucks more than worth it.
But I'm just seeing everyone else's opinion and if hey have done this as well. Thanks!
Old 01-16-2010, 08:58 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
PM sent.
Old 01-16-2010, 09:48 PM
Grifter's Avatar
You're a fool if you don't buy one while you're doing the clutch. A quick search in this section will show that bleeding our systems is one of the biggest problems people have, with a remote bleeder it makes solving that problem so much easier.
Old 01-17-2010, 01:15 PM
slayerized6's Avatar
GO FOR IT. mine is routed right next to the clutch fluid resivior with a few inches of slack too.
Old 01-17-2010, 01:23 PM
Nimitz87's Avatar
without a doubt get it, you have to bleed the system so many times on these cars.
Chad
Old 01-17-2010, 02:21 PM
Pontiacerator
RevGTO's Avatar
If you're replacing a clutch, it's a no brainer.
Old 01-17-2010, 03:20 PM
6.0 silverado's Avatar
If you like having two people, jacking up your car, laying under it, getting fluid all over the inside of the bell housing/ floor, smashing your hand between the tunnel and the tranny just to get to the bleeder... then don't get one.
Old 01-17-2010, 03:24 PM
SWEET98SS's Avatar
Get it man, I got it, took 10 minutes to bleed it, just keep the reservoir full.
Old 01-17-2010, 04:28 PM
CranMaro99's Avatar
Originally Posted by araber89
PM sent.
Pm answered. Thanks.
Haha well it seemed like a no brainer but I wanted to see everyone thoughts on the subject. It seems to be well worth it especially considering the costs for a clutch swap anyways, might as well do it while I can.
Don't worry y'all I'll be installing one asap haha thanks!
Old 01-17-2010, 06:35 PM
MrEddie's Avatar
Definitely worth it! With a motive power bleeder, you just pressurize the system and submerge the extension line in brake fluid, and you're done quick - no need for a helper.
Old 01-18-2010, 02:11 AM
johnzss's Avatar
after working with my mechanic on my clutch job.. i WILL be ordering one from tick as well. From what i read, it needs to be installed while the tranny is off?
Old 01-18-2010, 02:36 AM
Yes. you need full access to the slave cylinder. you need to remove the stock bleed screw and then screw the speedbleeder line into the slave...it will be nearly impossible unless you remove the trans
Quick Reply: Tick Performance Remote Clutch bleeder Line Worth it?
