removing pedals
unhook your throttle cable from the accelerator pedal
then unhook your brake actuator rod from your brake pedal. there is a metal clip that you will need to remove to get this unhooked, they can be a bit of a pain. The same goes for your clutch master cyl.
there is the same type metal clip that holds your gas pedal on to your pedal assembly. remove the clip and your gas pedal.
now there is 4 studs that are attached to your brake booster that come through your firewall around your brake pedal, remove the 4 nuts from them.
Now on your master cyl there will be a U bolt that comes through your firewall also remove the 2 nuts from it.
Directly above the brake pedal there will be one more nut and bolt one going up vertically into the bottom of the dash and one horizontally both are 13mm as well.
after removing those just hold your tongue right and wiggle them out.
hope this helps.
hope this helps.
