help with clutch disk and preasure plate
Hey guys ca I reuse this pressure plate only has 1500 kms! Will the hot spots cause problems? Can you machine a pressure plate? Where can I buy just a clutch disk, and will a regular 11 inch disc 26 spline by 1.125 input shaft from any manufacture work with my spec pressure plate? I can't wait for them to loo at this I have to get this car back on the road.. help!! FIY my old disk "spec" only has 1500 kms on it but it is bent!
Damm sorry to hear about that man. Tranny rebuild goes great and then the da
m clutch gives u problems . From what I've seen spec clutches are a crapshoot . Good luck man.
