t56 pedals same for LT1 and LS1 or not?
Old 02-18-2010, 08:36 AM
efizjb's Avatar
Default t56 pedals same for LT1 and LS1 or not?
Searched threads and finding different answers. Can someone definately put to rest if they are different? Looking to swap A4 to M6 in LS1 and want to be sure before buying used pedals.
Thanks!
Old 02-18-2010, 09:44 AM
85MikeTPI's Avatar
The LS1 clutch pedal has a return assist spring, while the LT1 does not. AFAIK, that's the only major difference.
Old 02-18-2010, 10:48 AM
the_merv's Avatar
Does that Spring really make that much of a difference..it helps when installing a Master..lol
Old 10-30-2013, 04:15 PM
Rob WS6's Avatar
So aside from that return assist spring, there are no other differences? Reason I ask is because Ive got an lt1 clutch pedal setup and Id like to use it in the m6 swap Im getting ready to do in my 98.
Old 10-31-2013, 11:46 AM
Mikey 97Z M6's Avatar
You will be fine using the LT1 pedal assembly with the LS1 hydraulics. My 97 with LS swap is still using the stock pedals and 6sp.
Mike
Old 10-31-2013, 07:06 PM
Rob WS6's Avatar
Awesome, that's what I was hoping. Just one less part to track down. Need some ARP bolts and to find the little plastic clutch reservoir and Ill be good to go!
Quick Reply: t56 pedals same for LT1 and LS1 or not?
