Question about bleeding...
Old 03-11-2010, 09:01 PM
santizz5588's Avatar
Default Question about bleeding...
So tonight I did the drill mod to my 2000 Z28. When I went to bleed the system I did it like the write up says which was depress clutch - open bleeder - close bleeder - release pedal. So upon releasing the pedal everytime (about 10-15 times) we always had to pull the pedal off the floor. So I ended up having to pump the pedal with the bleeder closed about 50-60 times until the pedal was normal feeling. Is this normal?
Old 03-12-2010, 10:04 AM
RARON455's Avatar
did you bench bleed the master before installing, if not that is probably what took all the time, getting the air out of it.
Old 03-12-2010, 11:49 AM
yes but is it normal to have to pump the clutch pedal to build pressure?
Old 03-12-2010, 08:50 PM
CW00BlackTA's Avatar
Yes it is. When you open and close the bleeder, make sure you do it pretty fast. When I get close to being finished, I open and close it as fast as I can.
